TwinTurbo.NET: Nissan 300ZX forum - Another question
Another question
Goldchocobo
on June 08, 2015 at 7:43 PM
15 Is only at Idle..
posted by Cjw3
on June 08, 2015 at 06:53 PM
Could I unplug the TPS to "force" the ecu into hard idle, therefore guaranteeing an accurate ignition timing? Also, if this is the case, I would know I need to replace the TPS.
Ignition timing issues
Goldchocobo
16:11:13 06/08/15
Cjw3
18:53:44 06/08/15
Re: 15 Is only at Idle..
Goldchocobo
19:27:55 06/08/15
It's the Green/Red.. Lt Green/Red wire set
Cjw3
19:47:35 06/08/15
Another question -
Goldchocobo
19:43:00 06/08/15
You need to close the Wires together to get Idle Mode..
Cjw3
20:13:57 06/08/15
UPDATE
Goldchocobo
21:11:53 06/08/15
Yeah, don't use that loop...use the #1 coil wire. (n/m)
ChristopherTheOne
22:37:01 06/08/15
Take the timing off the first coil always, the loop's timing
puchy
22:37:27 06/08/15
I was testing both just to be thorough.
Goldchocobo
23:25:18 06/08/15
